LTA1311 QSFP28 PSM4 Transceiver
4 x25.78Gb/s 1310nm Transceiver
TA1311 is a QSFP28 Optical transceiver for 4 x 25Gb/s optical links. It is compliant with the QSFP28 PSM4 specifications. It operates at 25.78Gb/s up to 500m over single-mode fiber.
更多内容
LTA1311-PC+ QSFP28 PSM4 mpo 500m C Single-mode 1310nm 4x25Gb/s -5~2.0dBm -11.35dBm***
• Infiniband EDR interconnects.
• IEEE 802.3bm Ethernet
• OIF CEI-28G-VSR
• Up to 500m link on single-mode Fiber
• Silicon photonics Technology
• QSFP28 PSM4 MSA  Compliance
• Monitors function for bias, transmitted/received power, module temperature, and module supply
• Case Operating Temperature:
Commercial: 0 to 70ºC
RoHS II Compliance
