LTA8532 QSFP28 SR4 Transceiver
4 x 25.78Gb/s 850nm Transceiver with DDM
The LTA8532 is a QSFP28 Optical transceiver for 4 x 25Gb/s optical links. It is compliant with the QSFP28 MSA, IEEE P802.3bm 100GBASE- SR4 specifications. It operates at 25.78Gb/s up to 300m over  Om<sup>4</sup>  Multi-mode fiber.
更多内容
LTA8532-PC+ QSFP28 MPO 300m C Multi-mode 850nm 4x25Gb/s -9.1dBm~2.4dBm -11dBm
• Infiniband EDR interconnects.
• 100GBASE- SR4 Ethernet
• Up to 300m link on Om<sup>4</sup> Multi-mode Fiber
• QSFP28 MSA  Compliance
• Diagnostic monitors for VCSEL bias, transmitted power, received power, module temperature, and module supply
• RoHS II Compliance
