LTU8531 microQSFP SR4 Transceiver
4 x 25.78Gb/s 850nm Transceiver
The LTU8531 is a microQSFP Optical transceiver for 4 x 25Gb/s optical links. It is compliant with the microQSFP MSA, IEEE P802.3bm 100GBASE-SR4 specifications. It operates at 25.78Gb/s up to 100m over OM4 Multi-mode fiber.
更多内容
LTU8531-BC+ microQSFP MPO/MTP 100m C Multi-mode 850nm 4x25Gb/s -5~2.4dBm -5dBm***
• Infiniband EDR interconnects.
• 100GBASE-SR4 Ethernet
• High performance computing interconnect
• Hot Pluggable • Up to 100m link on OM4 Multi-mode Fiber
• microQSFP MSA Compliance
• Monitors for TX power,VCSEL bias, received power, module temperature, and module supply
• Case Operating Temperature:
Commercial: 0 to 70ºC
 RoHS II Compliance
