LTH4301 XFP 10G EPON OLT Transceiver
Three Lambda 10G/1G Asymmetrical Tri-plexer
The LTH4301 is a combination of 10G EPON OLT and 1G EPON OLT optical transceivers in an XFP housing.
It is configured with a 1577nm 10.3125Gbps EML and a 1490nm 1.25Gbps DFB laser with a 1.25Gbps 1310nm APD/TIA receiver for maximum sensitivity.
The transmitters can be controlled by the LVTTL Tx_DISABLE function and the receivers incorporates the LVTTL Rx_LOS output.
10G EPON OLT LTH4301-PC+ XFP SC 20km C 2~5dBm
2~7dBm
10.3125Gb/s
1.25Gb/s
1577nm
1490nm
-29.78dBm 1.25Gb/s 1310nm
•  10G Ethernet Passive Opitacal Access Network
•  Fiber to the Home
•  Fiber to the Building
•  Fiber to the Curb
•  3.3V and 5V DC power supply
•  3 Lambda
•  SC receptacle optical connector
•  Hot pluggable
•  2x15 XFP Electrical Interface
•  Standards:
   IEEE802.3ah PX-20D
   IEEE802.3av PRX-30D
   RoHS
