LTF5302 SFP+ 10G EPON OLT Transceiver
Four Lambda 10G / 1G Symmetrical Quadplexer
The LTF5302 is a combination of 10G EPON OLT and 1G EPON OLT optical transceivers in a SFP+ housing.The 10G bidirectional link is configured with 1270nm/1577nm optics and the 1G link is configured with 1310nm/1490nm optics. The 1270nm and 1310nm optical burst mode receivers incorporate APD/TIA optics for maximum sensitivity. The 10G transmitter incorporates a 1577nm EML DFB laser assembly and the 1G transmitter incorporates a 1490nm DFB laser assembly.  The transmitters can be controlled by the LVTTL Tx_DISABLE function and the receivers incorporates the LVTTL Rx_LOS output.
10G EPON OLT LTF5302-BC+ SFP+ SC 20km C 2~5dBm
2~7dBm
10.3125Gb/s
1.25Gb/s
1577nm
1490nm
-28dBm
-29.78dBm
10.3125Gb/s
1.25Gb/s
1270nm
1310nm
•  10G Ethernet Passive Opitacal Access Network
•  Fiber to the Home
•  Fiber to the Building
•  Fiber to the Curb
•  SFP+ Package
•  3.3V DC power supply
•  4 Lambda
•  SC receptacle optical connector
•  Hot pluggable
•  SFP+ Electrical Interface
•  IEEE802.3ah PX-20D compliant
•  IEEE802.3av PR-30D compliant
•  Optical Transmitter
   1577nm CW Mode EML
   10.3125Gb/s data rate
   LVCML AC Coupled input
   1490nm CW Mode DFB Laser
   1.25Gb/s data rate
   LVPECL AC Coupled input
•  Optical Receiver
   1270nm Burst Mode APD/TIA receiver
   LVCML DC Coupled output
   1310nm Burst Mode APD/TIA receiver
   1.25Gb/s data rate
•  LVPECL DC Coupled output
•  Control and Monitor Interface
   LVTTL Tx_Disable
   LVTTL Rx_LOS
   LVTTL Rx_RSSI_Tri
•  I2C Serial Data
•  SCL Serial Clock Input
•  SDA Serial Data I/O
