LTA8541 QSFP28 SR8 Transceiver 8 x25.78Gb/s 850nm Transceiver
The LTA8541 is a QSFP-DD Optical transceiver for 8 x 25Gb/s optical links. It is compliant with the QSFP-DD MSA specifications. It operates at 25.78Gb/s up to 100m over  OM4  Multi-mode fiber.
更多内容
LTA8541-PC+ QSFPDD MPO/MTP 100m C Multi-mode 850nm 8x25Gb/s -8.4~2.4dBm -10.3dBm***
• 8 independent parallel optical channels
• Up to  70m link on OM4 Multi-mode with 1E-12 BER operation
• Up to 100m link on OM4 Multi-mode with 5E-05 BER operation and host side enable FEC
• QSFP-DD MSA Compliance
• Monitors for VCSEL bias, transmitted, received power, module temperature, and module supply
• Case Operating Temperature:
Commercial: 0 to 70ºC
RoHS II Compliance
