LTF1325 SFP28 Optical Transceiver
24.33Gb/s to 25.78Gb/s 1310nm 10km
The LTF1325  is intended for 10km reach service from 24.33Gb/s to 25.78Gb/s 1310nm single mode high-speed communications equipment where low-cost, extraordinary performance and reliability are essential. It consumes low power, operates base on 3.3V DC power supply and is offered in the commercial temperature range. They are compliant with  SFP28 MSA , SFF-8431  and SFF-8432. The low jitter and low bit error rate optical assembly features a 1310nm DML laser transmitter and PIN/TIA receiver.
更多内容
LTF1325-BC+
LTF1325-BH+
SFP28 LC 10km C,H Single-mode 1310nm 24.33~25.78G -5~3dBm -10.6dBm
• 25G BASE-LR Ethernet
• CPRI 25G
• OTU4
• LC Duplex optical interface
• Maximum link length of 10km
• 24.33Gb/s to 25.78Gb/s data links
• Power consumption<1.5W
• High performance 1310 nm DML laser
• Built-in CDR
• Standards:
   SFP28 MSA
   SFF-8431
   SFF-8432
