LTA8512 QSFP+ eSR4 Transceiver
4 x 10.3125Gb/s 850nm Transceiver
The LTA8512  is a QSFP+ Optical transceiver for 40GBASE-SR4 Ethernet and 4x10G InfiniBand applications,and which also supports optical interoperability with IEEE 10GBASE-SR compliant products. This transceiver is compliant with SFF-8436 QSFP+ MSA, IEEE802.3ba 40GBASE- SR4 specifications. It operates at 10.3125Gb/s up to 300m over  Om<sup>3</sup> multimode optical fiber.
更多内容
LTA8512-PC+ QSFP+ MPO 300m C Multi-mode 850nm 4x10Gb/s -7.6~-1dBm -7.5dBm
• 40GBASE- SR4 Ethernet
• Infiniband QDR interconnects
• Breakout 10GBASE-SR Ethernet
• Each channel data rate up to 10.3125Gb/s
• Hot Pluggable QSFP+ form factor
• Up to 300m link on Om<sup>3</sup> MMF
• Maximum power consumption <1.5W
• QSFP+ MSA  Compliance
• RoHS II Compliance
