DEF8503 QSFP28 to 4xSFP28 AOC
100Gb/s to 4x25.78Gb/s Active Optical Cable
The DEF8503 is a QSFP28 active optical cable (AOC) to 4× SFP28 Active Optical Cable break-out. It operates at 25.78Gb/s and the cable length is up to 100m. QSFP28 AOC end is compliant with the QSFP28 MSA, IEEE802.3bm 100GBASE- SR4 specifications. Each SFP28 end is compliant with the SFF8431 specification and SFF8432  MSA.
DEF8503-4CXX SFP28/QSFP28 Cable 1~100m C Multi-mode 850nm 100Gb/s/4x25Gb/s - -
• Infiniband EDR interconnects
• 100GBASE- SR4 Ethernet
• Channel data rate up to 25.78Gb/s with integrated CDR
• Up to 100m link over OM4 Multi-mode Fiber
• BER<1E-12
• QSFP28 MSA  Compliance
• SFP28 MSA Compliance
• CAUI-4 Compliance
Commercial: 0 to 70ºC
RoHS compliance
