LTM4301 CSFP Optical Transceiver
1000BASE-BX10 1490nmTx/1310Rx 10km With DDM
The LTM4301 CSFP LC 2-Channel bidirectional transceiver is designed for 1250Mb/s  10km Gigabit Ethernet data links.LTM4301 is an CSFP device designed with the IEEE802.3ah 1000BASE-BX standard.It onsumes low power, operates from a 3.3V DC powersupply and is offered in the commercial and industrial temperature ranges.
It has low jitter and low bit error rate optical assembly features a 1490nm DFB laser transmitter and 1310nm PIN/TIA receiver.
更多内容
1.25G CSFP LTM4301-BC+
LTM4301-BH+
CSFP LC 10km C,H -9~-3dBm 1.25Gb/s 1490nm -19.5dBm 1.25Gb/s 1310nm
• 1250Mb/s Gigabit Ethernet data links
• Channel extenders
• Bus extenders
• High speed I/O file servers
• Data storage networks
• LAN
• SAN
• RSAN
• Host adapters
• Switch-to-switch interfaces
• Mass storage system interconnects
• Hub interconnects
• LC Duplex optical interface
• +3.3V power supply
• Low DC power consumption
• Comply with CSFP MSA Option2
• Bail Latch
• Hot swappable
• 2 Channel Bidirectional Optical Transceiver unit :
   1490nm DFB laser
•  IEEE 802.3ah 1000BASE-BX10 compliant
• Monitor and Control Functions
• Loss of Signal (Rx1_LOS,Rx2_LOS)
• Tx Disable (Tx1_DIS,Tx2_DIS), LVTTL
• Tx Fault (Tx_FAULT), LVTTL
• 2-wire I2C data bus
• Internally AC coupled and terminated
• RoHS compliance
