LTM3401 CSFP Optical Transceiver
1000BASE-BX10 1310nmTx/1490Rx 10km With DDM
The LTM3401 CSFP LC 2-Channel bidirectional transceiver is designed for 1250Mb/s  10km Gigabit Ethernet data links.LTM3401 is an CSFP device designed with the IEEE802.3ah 1000BASE-BX standard.It onsumes low power, operates from a 3.3V DC powersupply and is offered in the commercial and industrial temperature ranges.
It has low jitter and low bit error rate optical assembly features a 1310nm F-P laser transmitter and 1490nm PIN/TIA receiver.
更多内容
1.25G CSFP LTM3401-BC+
LTM3401-BH+
CSFP LC 10km C.H -9~-3dBm 1.25Gb/s 1310nm -20dBm 1.25Gb/s 1490nm
• 1250Mb/s Gigabit Ethernet data links
• Channel extenders
• Bus extenders
• High speed I/O file servers
• Data storage networks
• LAN
• SAN
• RSAN
• Host adapters
• Switch-to-switch interfaces
• Mass storage system interconnects
• Hub interconnects
• LC Duplex optical interface
• +3.3V power supply
• Low DC power consumption
• Comply with CSFP MSA Option2
• Hot swappable
• 2 Channel Bidirectional Optical Transceiver unit :
   1310nm F-P laser
   Single Mode operation
• IEEE 802.3ah 1000BASE-BX10 compliant
• Monitor and Control Functions
• SFF-8472 Rev 9.5 MSA compliant
• Internally AC coupled and terminated
• RoHS compliance
