LTM2305 DSFP+ Bidirectional Transceiver 10Gb/s 10km
10Gb/s 10km
The LTM2305 Compact SFP+ transceiver is intended for 10km reach service from 9.95Gb/s to 10.3125Gb/s 1270nm/1330nm single mode high-speed communications equipment where low-cost, extraordinary performance and reliability are essential. It consumes low power, operates over the commercial and industrial temperature ranges .The low jitter and low bit error rate optical assembly features a 1270nm DFB laser transmitter and a PIN/TIA receiver.
更多内容
10G BIDI DSFP LTM2305D-BC+ LTM2305D-BH+ DSFP LC 10km C.H -8.2~0.5dBm 10.3125Gb/s 1270nm -14.4dBm 10.3125Gb/s 1330nm
• High-speed storage area networks
• Computer cluster cross-connect
• Custom high-speed data pipes
• 2x10 Compact SFP+ Package Outline
• Single Fiber, Dual LC interface, Full Duplex Operation
• LC Optical Interface
• 1270nm CW Mode DFB Optical Transmitter
• 1330nm CW Mode PIN Optical Receiver
• IEEE 802.3ae Base-LR/LW
• SFP+ MSA
• Compliant with RoHS
