LTF3204 SFP+ Bidirectional Transceiver
10Gb/s 40km
The LTF3204 SFP+ transceiver is intended for 40km reach service from 9.95Gb/s to 10.3125Gb/s 1330nm/1270nm single mode high-speed communications equipment where low-cost, extraordinary performance and reliability are essential. It consumes low power, operates over the commercial and industrial temperature ranges and employs a single 3.3V DC power supply. The low jitter and low bit error rate optical assembly features a 1330nm DFB laser transmitter and a 1270nm APD/TIA receiver. It incorporates the SFP+ MSA LVTTL Loss of Signal (Rx_LOS), Tx Fault (Tx_FAULT), MOD_ABS and Tx Disable (Tx_DIS) monitor and control functions. The differential AC coupled Tx and Rx data interfaces are CML compatible. The device is Class I laser safety compliant
10G BIDI | LTF3204-BC+ LTF3204-BH+ |
SFP+ | LC | 40km | C,H | 0~5dBm | 10.3125Gb/s | 1330nm | -18dBm | 10.3125Gb/s | 1270nm |
• High-speed storage area networks
• Computer cluster cross-connect
• Custom high-speed data pipes
• IEEE 802.3ae Base-ER/EW
Single 3.3V DC Supply
• 40km Reach
• 2x10 SFP+ Package Outline
• LC Optical Interface
• Dual Wavelength (WDM) Bidirectional
Transmissionter
• BER<10-12 (PRBS 231
-1, 10.3125Gb/s)
• RoHs Compliance
• 9.95 to 10.3125Gb/s Data Rate
• 1330nm CW Mode DFB Optical Transmit
