LTY9775M GPON ONU Triplexer
CLASS B+ 1244/2488Mb/s With Digital RSSI Function
The LTY9775M is a 2488Mb/s downstream / 1244Mb/s upstream GPON ONU triplexer transceiver designed to meet the requirements of the ITU-T G.984.5 Class B+ specification for point to multi point service in advanced “triple play” Optical Network Termination (ONT) or Optical Network Unit (ONU) equipment.
更多内容
Triplexer LTY9775 Triplexer SC/APC 20km C,H 0.5~5dBm 1.25Gb/s 1310nm -28dBm 2.5Gb/s 1490nm
•  Passive Opitacal Access Network
•  Fiber to the Home
•  Fiber to the Building
•  Fiber to the Curb
•  Optical Features
   Single Fiber Triplexer
   1244Mb/s 1310nm DFB Upstream Burst Mode Transmitter
   2488Mb/s 1490nm APD/TIA Downstream
•  CW Mode Digital Receiver
   1550nm Downstream Linear CATV Video Receiver
   SC/APC Fiber Pigtail
•  Mechanical Features
   20-Pin SIL 2.00 x 2.00 Inch Package
•  RF / Electrical Features
   3.3V Burst Mode Transmitter
   3.3V Digital Receiver
   12.0V Video Receiver
   2.5W Typical Room Power Consumption
   47MHz  to 870/1002MHz RF BW
   17dBmV / ch with 4dB positive tilt RF
•  Output
   75-Ohm Single-Ended RF Output
   RF Output Level AGC Adjustment
   RF Output Squelch
   Video Supply Shut Down Separately
•  Settings with no Additional Calibration
•  IIC Diagnostic and Control Functions
   Transceiver Temperature
   Tx and Rx Supply Voltage
   Burst Mode Tx Power
   Tx BIAS Current
   Laser Transmitter Failure
   Pon Loss of Signal
   Rx Receiver Power
   Video Receiver Power
   Tx  Laser Soft Disable Control
   Soft switch enable or disable RF output
•  Applied Standards
   ITU-T G.984.2
   ITU-T G.984.5 filter
   FSAN Class B+
   RoHS Compliance
