LTE3415 SFP GPON ONU STICK Transceiver Class B+ 1244/2488Mbps with MAC
The LTE3415 with SC recepticle is standard 2*10 SFP GPON ONU with MAC module, which is designed to meet the requirements of ITU-T G984 standard.
GPON ONU STICK LTE3415-SC+ SFP SC/APC 20km C 0~5dBm 1.25Gb/s 1310nm -28dBm 2.5Gb/s 1490nm
•  Home Gateway
•  Network switch
•  Router
•  MDU
•  Dual Lambda Bidirectional Transceiver
•  Single 3.3V DC supply
•  Low Power Consumption
•  Full Duplex Operation
•  SFP Package Outline
    1310nm 1244Mb/s  DFB Burst Mode Laser
    1490nm 2488Mb/s TIA CW Mode Receiver
•  Standards
ITU-T G.984.2
    ITU-T G.984.5
    FSAN Class B+
ROHS 6
