LTW63XX XFP NG-PON2 OLT Transceiver Asymmetrical 9.953/2.488Gb/s With Digital RSSI
The LTW63XX is intended for NG-PON2 OLT application in four separate XFP housing. It is a series module and each module is configured with a L-band 9.95328Gbps downstream transmitter and a C-band 2.48832Gbps upstream receiver which work in TDM configuration. The transmitters can be controlled by the LVTTL Tx_DISABLE function and the receivers incorporates the LVTTL Rx_SD output.
The LTW63XX is designed to support up to 32 subscribers over distances of up to 20km in the ODN.  It is FDA 21CFR1040.10 and IEC 60825-2 Class I laser safety compliant and meets the EEC Directive 2002/95/EC for RoHS compliance.
更多内容
NG-PON2 OLT LTW63XX-PC+ XFP SC 20km C 5.5~dBm 9.953Gbps 1596.34/1597.19/
1598.04/1598.89nm
-28.5dBm 9.953Gbps 1532~1540nm
• 40G NG-PON2 Passive Opitacal Access Network
• Fiber to the Home
• Fiber to the Building
• Fiber to the Curb
• Refer to ITU-T G.989.2
• XFP
• SC Duplex optical inerface
• 1596.34nm,1597.19nm,1598.04nm,1598.89nm 9.953Gbps downstream with EML+SOA 1524~1544nm 2.488Gbps upstream with APD
• Up to 20km link on SMF single-mode fiber
• Power Consumption <3.5W
