LTW2601 XFP NG-PON2 ONU Transceiver
Beta2+ Symmetrical 9.953Gbps ONU
The LTW2601 is intended for NG-PON2 ONU applicat with a C-band 9.95328Gbps BM upstream transmitter and a L-band 9.95328Gbps CW downstream in XFP housing.
The module is configured receiver which work in TDM configuration. The transmitters can be controlled by the LVTTL Tx_Disable function and the receivers incorporates the LVTTL Rx_LOS output.
The LTW2601 is designed to support up to 32 subscribers over distances of up to 20km in the ODN.
It is FDA 21CFR1040.10 and IEC 60825-2 Class I laser safety compliant and meets the EEC Directive 2002/95/EC for RoHS compliance.
NG-PON2 ONU LTW2601-BCA+ XFP SC 20km C 4~9dBm
@ER≥6dB
9.953Gb/s 1532.68/1533.47/
1534.25/1535.04nm
-28dBm 9.953Gb/s 1596.34/1597.19/
1598.04/1598.89nm
•  NG-PON2 Access networks
•  Fiber to the Home
•  Fiber to the Building
•  Fiber to the Curb
•  XFP Package
•  Single 3.3V DC power supply
•  2 Lambda
•  Single SC receptacle optical connector
•  Hot pluggable
•  2x15 XFP Electrical Interface
•  Optical Transmitter
   C-band Burst Mode EML
    9.95328Gb/s data rate
    4X100GHz Tunable
    LVCML AC Coupled input
•  Optical Receiver
    CW APD/TIA receiver
    4X100GHz Tunable
    LVCML AC Coupled output
•  Control and Monitor Interface
    LVTTL Tx_Disable
    LVTTL Mod_Abs
    LVTTL Rx_LOS
    LVTTL Tx_SD
    LVTTL Mod_Disable
•  I2C Serial Data
    SCL Serial Clock Input
    SDA Serial Data I/O
