LTF62XX SFP+ NG-PON2 OLT Transceiver
Symmetrical 9.953Gbps OLT
The LTF627X is intended for NG-PON2 OLT application in four separate SFP+ housing. It is a series modules and each module is configured with a L-band 9.95328Gbps downstream transmitter and a C-band 9.95328Gbps upstream receiver which work in TDM configuration. The transmitters can be controlled by the LVTTL Tx_DISABLE function and the receivers incorporates the LVTTL Rx_SD output.
The LTF627X is designed to support up to 32/64 subscribers over distances of up to 20km in the ODN. It is FDA 21CFR1040.10 and IEC 60825-2 Class I laser safety compliant and meets the EEC Directive 2002/95/EC for RoHS compliance.
NG-PON2 OLT LTF62XX-PC+
LTF62XX-PCA+
SFP+ SC 20km C 5.2~dBm
7.2~10.2dBm
9.953Gb/s 1596.34/1597.19/1598.04/1598.89nm -29.2dBm
-30.6dBm
9.953Gb/s 1524~1544nm
•   NG-PON2 Access networks
•   Fiber to the Home
•   Fiber to the Building
•   Fiber to the Curb
•  SFP+ Package
•  3.3V power supply
•  2 Lambda
•  Single SC receptacle optical connector
•  Hot pluggable
•  2x10 SFP+ Electrical Interface
