LTA8513 QSFP+ iSR4 Transceiver
4 x 10.3125Gb/s 850nm Transceiver
The LTA8513 is a QSFP+ Optical transceiver for 40GBASE-SR4 Ethernet and 4x10G InfiniBand applications,and which also supports optical interoperability with IEEE 10GBASE-SR compliant products. This transceiver is compliant with SFF-8436 QSFP+ MSA, IEEE802.3ba 40GBASE- SR4 specifications. It operates at 10.3125Gb/s up to 100m over  Om3 multimode optical fiber and 150m over Om4 fiber.
LTA8513-PC+ QSFP+ MPO 100m C Multi-mode 850nm 4x10Gb/s -7.6~-+0.5dBm -5.4dBm
• 40GBASE- iSR4 Ethernet
• Infiniband QDR interconnects
• Breakout 10GBASE-SR Ethernet
• Each channel data rate up to 10.3125Gb/s
• Hot Pluggable QSFP+ form factor
• Up to 100m link on Om3 MMF and 150m on Om4 MMF
• Maximum power consumption<1.5W
• QSFP+ MSA  Compliance
• RoHS II Compliance
