LTF8505 SFP28 Optical Transceiver
25G Ethernet 25.78Gb/s 850nm 100m
The LTF8505 SFP28 transceiver is intended for 100m reach service from 25.78Gb/s 850nm multi mode high-speed communications equipment where low-cost, extraordinary performance and reliability are essential. It consumes low power, operates from a 3.3V DC pow er supply .It is compliant with SFF-8431 and SFF-8432.
LTF8505-BC+
LTF8505-BH+
SFP28 LC 100m C,H Multi-mode 850nm 25Gb/s -8.4~2.4dBm -5.2dBm(OMA)
• 25G Ethernet
• LC Duplex optical interface
• Reach: max up to 100m on Om4 MMF
• Bit rate:25.78Gb/s
• +3.3 V power supply
• Low DC power consumption
• 2x10 SFP+  MSA compliant package
• High performance 850 nm VCSEL laser
• Multi Mode operation
• RoHS compliance
