LTA1303-PC+ QSFP+ Optical Transceiver
CWDM 4X10.3125Gb/s 2kM
The LTA1303 QSFP+ Optical transceiver is intended for the service with single mode fiber in 40Gb/s high speed data communications and computing applications. It meets the requirements of QSFP+ MSA, IEEE802.3ba 40GBASE-LR4, operates from a 3.3V DC power supply and is offered in the commercial temperature range. The module has an aggregate link bandwidth in excess of 40Gb/s by multiplexing of 4 CWDM optical lanes, each lane capable of transmitting 10.3125Gb/s over 2km on SMF optical fiber. It is fabricated with a rugged die cast metal housing and cage assembly. The device is Class I laser safety compliant and meets the EU Directive 2011/65/EU for RoHS compliance.
LTA1303-PC+ QSFP+ LC 2km C Single-mode 1271nm
1291nm
1311nm
1331nm
4x10Gb/s -9~+2.3dBm -11.5dBm
High performance computing, data com and sever data links
•  High speed access
•  40G Ethernet
4 independent optical lanes
•  Lane data rate of 10.3125Gb/s
•  Aggregate data rate in excess of 41Gb/s (over 4 lanes)
•  Hot Pluggable
•  2km link on SMF single-mode Fiber
•  CWDM Laser/ Pin PD Array Technology
•  QSFP+ MSA Compatible electrical I/O
•  Case Operating Temperature:
•  Commercial: 0 to 70ºC
•  +3.3V power supply
•  RoHS compliance
