LMQ8611 QSFP56 SR4 Transceiver
4x26.56GBaud 850nm Transceiver
The LMQ8611 is a QSFP56 Optical transceiver for 4x26.56GBaud optical links. It is compliant with the QSFP+ MSA. It operates at 26.56GBaud up to 100m over OM4 Multi-mode fiber.
LMQ8611-PC+ QSFP56 MPO 100m C Multi-mode 850nm 4x25Gb/s -6~4dBm(each lane) -8.4~4dBm (each lane)
• Data center
• Each channel typical data rate 26.56GBaud with integrated CDR
• Up to 100m link on OM4 Multi-mode Fiber
• QSFP+ MSA Compliance
• PAM4 modulation
• Case Operating Temperature:
Commercial: 0 to 70ºC
• RoHS II Compliance
