LMQ8511B-PC+ QSFP28 BIDI
Transceiver 850nm/908nm Transceiver
The LMQ8511B-PC+ is a QSFP28 transceiver for 4 x 25Gb/s interconnects. It is compliant with the QSFP28 MSA specifications, operates from a 3.3V DC power supply. It is fabricated with a rugged die cast metal housing and cage assembly
LMQ8511B-PC+ QSFP28 LC 100m C Multi-mode 850nm 908nm 4x25Gb/s -6.5~4dBm(each lane) -8.5~4dBm (each lane)
• Data center
• QSFP28 MSA Specification Compliant, including new functions per SFF-8636
•100G Link Distances up to 70m over OM3, 100m over OM4
• Dual Wavelength VCSEL Bi-Directional Optical Interface, PAM4 2x50Gbps 850nm/908nm
• Interface with Digital Monitoring and Maskable Interrupts for Expanded Functionality
 • Case Operating Temperature:
• Range: 0 to 70ºC
• RoHS II Compliance
