LMQ3921S-PC+ Transceiver 4x100G 500m QSFP-DD DR4 Transceiver
The LMQ3921S-PC+ is a QSFP-DD Optical transceiver for 4x100Gb/s optical links. It is compliant with the of QSFP-DD MSA specifications. It operates at 53.125GBaud up to 500m over single-mode fiber.
LMQ3921S-PC+ QSFP-DD MPO 500m C Single-mode 1310nm 4x100Gb/s -2.9~4dBm(each lane) -5.9~4dBm (each lane)
• Data center
• 8 independent electrical input/output channels
• MPO optical connector
• 500m link on SMF single-mode Fiber
• Silicon photonics Technology
• QSFP-DD MSA Compliance
• Case Operating Temperature:
•  Commercial: 0 to 70ºC
• RoHS II Compliance
