DQF8501 QSFP+ SR4 4X10.3125Gb/s QSFP+ SR4 Active Optical Cable
The DQF8501 is a QSFP+ active optical cable (AOC) for 40Gb/s optical links. It is compliant with the QSFP+ MSA, IEEE802.3ba 40GBASE- SR4 specifications. It operates at 10.3125Gb/s and the cable length is up to 100m .
DQF8501-4Cxx QSFP+ Cable 1~100m C Multi-mode 850nm 4x10Gb/s - -
• Infiniband QDR interconnects.
• 40GBASE- SR4 Ethernet
• Channel data rate up to 10.3125Gb/s
• Up to 100m link on Multi-mode Fiber
• QSFP+ MSA  Compliance
• Diagnostic monitors for VCSEL bias, received power (optional),module temperature, and module supply
• RoHS compliance
