DQF8503 QSFP28 AOC
4X25.78Gb/s QSFP28 Active Optical Cable
The DQF8503 is a QSFP28 active optical cable (AOC) for 100Gb/s optical links. It is compliant with the QSFP28 MSA, IEEE P802.3bm 100GBASE- SR4 specifications. It operates at 25.78Gb/s and the cable length is up to 100m .
DQF8503-4CXX
DEF8503-4EXX
QSFP28 Cable 1~100m C Multi-mode 850nm 4x25Gb/s - -
• Infiniband EDR interconnects.
• 100GBASE- SR4 Ethernet
• Channel data rate up to 25.78Gb/s
• Up to 100m link over Om4 Multi-mode Fiber
• QSFP28 MSA  Compliance
• RoHS compliance
