DQF8504 QSFP-DD AOC
8×25.78Gb/s Active Optical Cable
The DQF8504 is a QSFP-DD active optical cable (AOC) for 8 x 25Gb/s optical links. It is compliant with the QSFP-DD MSA specifications.  It operates at 25.78Gb/s and the cable length is up to 100m .
DQF8504-4CXX QSFP-DD Cable 1~100m C Multi-mode 850nm 8x25Gb/s - -
• 8 independent parallel optical channels
• Up to 100m link over OM4 Multi-mode Fiber with 5E-05 BER
  operation and host side enable FEC
• QSFP-DD MSA  Compliance
Commercial: 0 to 70ºC
RoHS compliance
