DME8811 QSFP-DD to QSFP56 AOC
400G to 2x200G Active Optical Cable
The DME8811A is a QSFP-DD active optical cable (AOC) to 2x QSFP56 active optical break-out. It is compliant with the QSFP56 MSA specifications.  It operates at 26.56GBaud and the cable length is up to 100m.
DME8811-ECXX QSFP-DD/QSFP56 Cable 1~100m C Multi-mode 850nm 8x50Gb/s - -
• Data center
• Each channel data rate up to 26.56GBaud with integrated CDR
• Hot Pluggable
• Up to 100m link over OM4 Multi-mode
• CML Compatible electrical I/O
• PAM4 modulation
• QSFP-DD  MSA  Compliance
• QSFP56  MSA  Compliance
• Case Operating Temperature Range:
• Commercial: 0 to 70ºC
• RoHS compliance
• Support 25G NRZ / 50G PAM4 rate select ability
• CMIS 4.0 for QSFP-DD side and SFF8636 for QSFP56 side
