LTA8531 QSFP28 SR4 Transceiver
4 x24.33Gb/s 850nm Transceiver with Monitor Function
The LTA8531 is a QSFP28 Optical transceiver fo 100GBASE-SR4 specifications. It operates at 24.33Gb r 4x24.33Gb/s optical links. It is compliant with the QSFP28 MSA, IEEE P802.3bm /s up to 100m over OM4 Multi-mode fiber.
LTA8531-PC+
LTA8531-PE+
QSFP28 LC 100m C,E Multi-mode 850nm 4x25Gb/s -8.4~-2.4dBm -7.2dBm
• CPRI
• 100GBASE- SR4 Ethernet
• Up to 100m link on OM4 Multi-mode Fiber
• QSFP28 MSA Compliance
• Optical connectivity via industry standard MPO/MTP terminated
fiber ribbon
• Monitors for VCSEL bias, transmitted and received power, module
temperature, module supply
• Case Operating Temperature:
  Commercial: 0 to 70ºC
• RoHS II Compliance
• Temperature E refers to -20℃-85℃
