LTF8505 SFP28 Optical Tranceiver
24.33Gb/s CPRI 850nm 100m
The LTF8505 SFP28 transceiver is intended for 100m reach service from 24.33Gb/s 850nm multi mode high ment where low-cost, extraordinary performance and reliability are essential. It consumes low power, operates from a 3.3V DC pow -speed communications equip- er supply .It is compliant with SFF-8431. The low jitter and low bit error rate optical assembly features a 850nm VCSEL laser transmitter and PIN/TIA receiver. It incorporates the SFP+ MSA LVTTL Loss of Signal (Rx_LOS), Tx Fault (Tx_FAULT), MOD_ABS and Tx Disable (Tx_DIS) monitor and control functions. The differential AC coupled Tx and Rx data interfaces are CML compatible. The device is Class I laser safety compliant.
LTF8505-BC1
LTF8505-BE1
SFP28 LC 100m C,E Multi-mode 850nm 24.33Gb/s -8.4~-2.4dBm -10.3~2.4dBm
• Wireless
• LC Duplex optical interface
• Reach: max up to 100m on OM4 MMF
• Bit rate:24.33Gb/s
• +3.3 V power supply
• Low DC power consumption
• 2x10 SFP28 MSA compliant package
• Hot swappable
• High performance 850 nm VCSEL laser
• Multi Mode operation
• Case Operating temperature range:
   Commercial: 0 to 70ºC
   Extended: -10 to 85ºC
•  Data and Control Interfaces:
• Tx Data CML/AC Coupled
• Rx Data CML/AC Coupled
• Tx_DIS LVTTL
• Tx_FAULT LVTTL
• Rx_LOS LVTTL
• MOD_ABS LVTTL
• 2-wire I2C data bus
• RoHS compliance
• Temperature E refers to -20ºC-85ºC
