LTF8508 SFP28 Optical Transceiver
32G Fiber Channel 28.05Gb/s 850nm 100m
The LTF8508 SFP+ transceiver is designed for usi rate over multimode fiber .It consumes low power, ng in Fiber Channel links up to 28.05 Gbps data operates from a 3.3V DC power supply and is offered in the commercial temperature range.
更多内容
LTF8508-BC+ SFP28 LC 100m C Multi-mode 850nm 32Gb/s -6.2~2dBm 95uW
• 32G Fiber Channel
• LC Duplex optical interface
• Reach: max up to 100m on Om<sup>4</sup> MMF
• Bit rate:28.05Gb/s
• +3.3 V power supply
• Multi Mode operation
