LTF8504 SFP+ Optical Transceiver
16G Fiber Channel 14.025Gb/s 850nm 100m
The LTF8504 SFP+ transceiver is designed for using in Fiber Channel up to 14.025Gb/s over multimode fiber. It is compliant with Rev.6.01,SFF-8431 and SFF-8432. It consumes low power, operates from a 3.3V DC power supply and is offered in the commercial te FC-PI-5 mperature range.
更多内容
LTF8504-BC+ SFP+ LC 100m C Multi-mode 850nm 16Gb/s -7.8~0dBm -10.5dBm
• 4.25/8.5/14.025Gb/s Fiber Channel
• LC Duplex optical interface
• +3.3V power supply
• Bail latch
• Hot swappable
• High performance 850nm VCSEL laser
• Multi Mode operation
• BER < 1X10-12
 (PRBS 231-1 NRZ test pattern)
• Internally AC coupled and terminated
• RoHS compliance
