LTF7221 SFP+ XGPON ONU Transceiver
The LTF7221 is a XGPON ONU duplex optical transceiver designed for low cost point-to-multipoint (P2MP) Fiber to the Home (FTTH), Business or Curb (FTTx) applications.
 It employs a 1577nm CW mode downlink ADP/TIA receiver operating at 9.95328Gb/s and a 1270nm DFB burst mode uplink transmit-ter operating at 2.48832Gb/s.
The LTF7221 is designed to be backward compatible with legacy G PON systems.
 It is housed in a rugged die cast SFP+ package with a SC optical receptacle and is designed to operate over the commercial and industrial temperature ranges.
The transceiver requires a single 3.3V power supply.
It is FDA 21CFR1040.10 and IEC 60825-2.Class I laser safety compliant and meets the EEC Direc-tive 2002/95/EC for RoHS compliance.
更多内容
XGPON1 ONU LTF7221-BC+
LTF7221-BH+
SFP+ SC 20km C, H 2~7dBm 2.48832Gb/s 1270nm -28dBm 9.95328Gb/s 1577nm
•  10G Gigabit Passive Opitacal Access Network
•  Fiber to the Home
•  Fiber to the Building
•  Fiber to the Curb
•  Dual Wavelength Single Fiber
•   Internal WDM Filter
•  Bidirectional Transceiver
•  2x10 SFP+ Die Cast Housing
•  SC Optical Receptacle
•  Single 3.3V DC Input Voltage
•  Downlink CW Mode Receiver
  9.95328Gb/s Data Rate
  1577nm APD/TIA
  LVCML AC Coupled Signal Output
  LVTTL Rx_LOS
•  Uplink Burst Mode Transmitter
  2.48832Gb/s Data Rate
  1270nm DFB Laser
  LVPECL AC Coupled Signal Input
  LVTTL BEN_Enable
