LTF7225 XGS-PON ONU Transceiver
The LTF7225 XGS-PON ONU Transceiver module has been designed for low cost Point-to-Multi Point (P2MP) Fiber to the Home (FTTH), Business or Curb (FTTx) applications employing high-speed Burst Mode TDM Upstream at 9.95328Gb/s and CW Downstream at 9.95328Gb/s.  It is fabricated with a  die cast metal housing and cage assembly and the electrical interface refers to the industry standard SFP+. It is FDA 21CFR1040.10 and IEC 60825-2.Class I laser safety compliant and meets the EEC Directive 2002/95/EC for RoHS compliance.
XGSPON ONU LTF7225-BC+
LTF7225-BH+
LTF7225-BHA+
SFP+ SC 20km C, H 4~9dBm 9.953Gb/s 1270nm -28dBm 9.953Gb/s 1577nm
•  Symmetric XGS-PON Access networks
•  FTTH
•  FTTB
•  FTTC
•  2x10  SFP+  Die Cast Housing
•  SC Optical Receptacle
•  One single-mode fiber
•  Bidirectional Operation
•  Dual Wavelength
•  Low Power Consumption
•  9.95328Gb/s Burst Mode Tx Data Rate
•  9.95328Gb/s CW Mode Rx Data Rate
•  Single 3.3V DC Input Voltage
•  Case Operating Temperature Ranges:
         Commercial: 0 to 70 ºC
          Industrial: -40 to 85 ºC
