LTF3228 SFP28 Optical Transceiver
25Gb/s 40km
The LTF3228 SFP+ footprint transceiver is intended for 40km reach service from 24.33Gb/s to 25.78Gb/s Tx1310nm/Rx1270 single mode high-speed communications equipment where low-cost, extraordinary performance and reliability are essential. It consumes low power, operates base on 3.3V DC power supply and is offered in the Industrial temperature range. They are compliant with SFP28 MSA , SFF-8431 and SFF-8432. The low jitter and low bit error rate optical assembly features a 1330nm DML laser transmitter and APD/TIA receiver. It incorporates the SFP+ MSA LVTTL Loss of Signal (Rx_LOS), Tx Fault (Tx_FAULT), MOD_ABS and Tx Disable (Tx_DIS) monitor and control functions . It utilizes internal clock and data recovery (CDR) units on transmitter and the receiver chains for low jitter compliance. The differential AC coupled Tx and Rx data interfaces are CML compatible.
25G BIDI LTF3228-BH+ SFP28 LC 40km H 0~6dBm 25.78Gb/s 1310nm -18.5dBm 25.78Gb/s 1270nm
• 25G BASE-ER Ethernet
• CPRI 25G
• OTU4
• LC Bi-direction optical interface
• Maximum link length of 40km
• Low DC power consumption
• 2x10 SFP+ MSA compliant package
• High performance 1310 nm DML laser
• High sensitivity APD/TIA optical receiver
• Single Mode operation
• BER < 5X10-5
• Built-in CDR
尊敬的访客
本网站可能会收集用户的个人信息,包括但不限于姓名、联系方式、电子邮件地址、地理位置等。 这些信息将用于提供更好的用户体验和个性化服务。单击“接受”以激活它们或“如果你不想要就拒绝。 请参阅我们的《隐私政策》 ,以了解如何在我们的网站上使用它们的更多信息。您可以在您方便的时候在这里更改设置。
拒绝
接受
