LTF7215 SFP+ 10G EPON ONU Transceiver
The LTF7215 is a 10Gb/s EPON ONU duplex optical transceiver designed for low cost point-to-multipoint (P2MP) Fiber to the Home (FTTH), Business or Curb (FTTx) applications. It employs a 1577nm CW mode downlink ADP/TIA receiver operating at 10.3125Gb/s and a 1310nm DFB burst mode uplink transmitter operating at 1.25Gb/s.  The LTF7215 is designed to be backward compatible with legacy Gigabit Ethernet PON systems. It is housed in a rugged die cast SFP+ package with the SC optical receptacle and is de-signed to operate over the commercial and industrial  temperature ranges.The transceiver requires a single 3.3V power supply. It is FDA 21CFR1040.10 and IEC 60825-2.Class I laser safety compliant and meets the EEC Directive 2002/95/EC for RoHS compliance. The LTF7215 incorporates the monitor or control functions Tx_Burst and Rx_LOS.
10G EPON ONU LTF7215-BC+
LTF7215-BH+
SFP+ SC 20km C, H 0.62~5.62dBm 1.25Gb/s 1310nm -28.5dBm 10.3125Gb/s 1577nm
•  10G Ethernet Passive Opitacal Access Network
•  Fiber to the Home
•  Fiber to the Building
•  Fiber to the Curb
•  Dual Wavelength Bidi Transceiver
•  Single Fiber, Full Duplex Operation
•  2x10 SFP+ Package Outlines
•  SC Receptacle Optical connector
•  Single 3.3V DC Input Voltage
Optical Transmitter
  1.25Gb/s Data Rate
  1310nm DFB Laser
  LVPECL AC Coupled Signal Input
  LVTTL Tx Disable
•  Optical Receiver
  10.3125Gb/s Data Rate
  1577nm APD/TIA
  BER≤10-3, PRBS 2^31-1
 CML AC Coupled Signal Output
 LVTTL Rx_LOS
•  Control and Monitor Interface
  LVTTL Tx Fault
  LVTTL Tx_Burst
  LVTTL Mod_ABS
  LVTTL Tx_SD
  LVTTL Rx_Los
  LVTTL P_Down
