LMQ3618 QSFP-DD Transceiver
LAN-WDM 4x50G 10km
The LMQ3618 is a QSFP requirements of QSFP-DD MSA, operates from a 3.3V DC power supply and is offered in -DD Optical transceiver for 4X50Gb/s optical links. It meets the commercial temperature range. The module has an aggregate link bandwidth in excess of 200Gb/s by multiplexing of 4 LAN-WDM optical lanes, each lane capable of transmitting 26.5625GBd over 10km on SMF optical fiber. It is fabricated with a rugged die cast metal housing and cage assembly. The device is Class I laser safety compliant and meets the EU Directive 2002/95/EC for RoHS compliance.
Part Number | Package | Interface | Reach | Temp | Fiber Type | Wavelength | Rate | Tx Output | Rx Input |
LMQ3618-PC+ | QSFP-DD | LC | 10km | C | Single-mode | LAN-WDM | 200Gb/s | -3.4dBm~5.3dBm(each lane) | max (-7.2 ,SECQ -8.6)(OMA) |
• 200GBASE-LR4
• 4 independent optical lanes Lane data rate of 26.5625GBd
• LC optical connector,4x50G LAN-WDM
• 10km link on SMF single-mode Fiber
• LAN-WDM Laser/ Pin PD Array Technology
• QSFP-DD MSA Compatible electrical I/O
• Case Operating Temperature:Commercial: 0 to 70ºC
• +3.3V power supply
• RoHS compliance
