LTM3401 CSFP Optical Transceiver
1000BASE-BX10 1310nmTx/1490Rx 20km With DDM
The LTM3402 CSFP LC 2-Channel bidirectional transceiver is designed for 1250Mb/s 20km Gigabit Ethernet data links. LTM3402 is a CSFP device designed with the IEEE802.3ah 1000BASE-BX standard.It onsumes low power, operates from a 3.3V DC powersupply and is offered in the commercial and industrial temperature ranges.It has low jitter and low bit error rate optical assembly features a 1310nm F-P laser transmitter and 1490nm PIN/TIA receiver.
1.25G CSFP | LTM3402-BC+ LTM3402-BH+ |
CSFP | LC | 20km | C.H | -9~-3dBm | 1.25Gb/s | 1310nm | -23dBm | 1.25Gb/s | 1490nm |
• 1250Mb/s Gigabit Ethernet data links
• Channel extenders
• Bus extenders
• High speed I/O file servers
• Data storage networks
• LAN
• SAN
• RSAN
• Host adapters
• Switch-to-switch interfaces
• Mass storage system interconnects
• Hub interconnects
• LC Duplex optical interface
• +3.3V power supply
• Low DC power consumption
• Comply with CSFP MSA Option2
• Hot swappable
• 2 Channel Bidirectional Optical Transceiver unit :
1310nm F-P laser
Single Mode operation
• IEEE 802.3ah 1000BASE-BX10 compliant
• Monitor and Control Functions
• SFF-8472 Rev 9.5 MSA compliant
• Internally AC coupled and terminated
• RoHS compliance
