LTF5306 SFP+ OLT Transceiver
XG-PON/GPON Combo OLT Quadplexer
The LTF5306 is a combination of XG-PON OLT and GPON OLT optical transceiver in an SFP+ housing. It is designed to support both the new ITU-T G.987.2 XG-PON and the legacy ITU-T G.984.2 GPON specifications over a single fiber via coarse wave division multiplexing.
The XG-PON bidirectional link is configured with 1270nm/1577nm optics and the GPON link is configured with 1310nm/1490nm optics. The 1270nm and 1310nm optical burst mode receivers incorporate APD/TIA optics for maximum sensitivity. The 10G transmitter incorporates a 1577nm EML laser assembly and the 2.5G transmitter incorporates a 1490nm DFB laser assembly. The transmitters can be controlled by the LVTTL Tx_DISABLE function and the receivers incorporates the LVTTL Rx_SD output.
The LTF5306 is designed to support up to 32/64 subscribers over distances of up to 20km. It meets the EEC Directive 2015/863/EU for RoHS compliance.
XGPON&GPON Combo OLT N2-C+ LTF5306-BCA+ SFP+ SC 20km C 4~8dBm
3~7dBm
9.953Gb/s
2.488Gb/s
1577nm
1490nm
-29.5dBm
-30dBm (BER@10ˉ10)
-32dBm (BER@10ˉ4)
2.488Gb/s
1.244Gb/s
1270nm
1310nm
• 10 Gigabits Access networks
• FTTH
• FTTB
• FTTC
• SFP+ Package
• 3.3V DC power supply
• 4 Lambda
• Hot pluggable
• 2x10 SFP+ Electrical Interface
• ITU-T G.987.2
• ITU-T G.984.2
• YD-T 1688.8
尊敬的访客
本网站可能会收集用户的个人信息,包括但不限于姓名、联系方式、电子邮件地址、地理位置等。 这些信息将用于提供更好的用户体验和个性化服务。单击“接受”以激活它们或“如果你不想要就拒绝。 请参阅我们的《隐私政策》 ,以了解如何在我们的网站上使用它们的更多信息。您可以在您方便的时候在这里更改设置。
拒绝
接受
