LTF8502 SFP+ Optical Transceiver
10G Ethernet 9.95 to 11.3Gb/s 850nm 300m
The LTF8502 SFP+ transceiver is intended for 300m reach service from 9.95Gb/s to 11.3Gb/s 850nm multi mode high-speed communications equipment where low-cost, extraordinary performance and reliability are essential.
LTF8502-BC+ LTF8502-BH+ |
SFP+ | LC | 300m | C,H | Multi-mode | 850nm | 10Gb/s | -7.3~-1dBm | -11.1dBm |
• 10G BASE-SR/SW
• 10G Fiber Channel
• LC Duplex optical interface
• +3.3V power supply
• Bail latch
• High performance 850nm VCSEL laser
• Multi Mode operation
• BER < 1X10-12
(PRBS 231-1 NRZ test pattern)
• Internally AC coupled and terminated
• RoHS compliance
