LTH5302 XFP 10G EPON OLT Transceiver
Four Lambda 10G / 1G Symmetrical Quadplexer
The LTH5302 is a combination of 10G EPON OLT and 1G EPON OLT optical transceivers in an XFP housing.The 10G bidirectional link is configured with 1270nm/1577nm optics and the 1G link is configured with 1310nm/1490nm optics.The 1270nm and 1310nm optical burst mode receivers incorporate APD/TIA optics for maximum sensitivity.The 10G transmitter incorporates a 1577nm EML DFB laser assembly and the 1G transmitter incorporates a 1490nm DFB laser assembly. The transmitters can be controlled by the LVTTL Tx_DISABLE function and the receivers incorporates the LVTTL Rx_LOS output.
10G EPON OLT | LTH5302-PC+ | XFP | SC | 20km | C | 2~5dBm 2~7dBm |
10.3125Gb/s 1.25Gb/s |
1577nm 1490nm |
-28dBm -29.78dBm |
1270nm 1310nm |
• 10G Ethernet Passive Opitacal Access Network
• Fiber to the Home
• Fiber to the Building
• Fiber to the Curb
• XFP Package
• 3.3V and 5V DC power supply
• 4 Lambda
• Hot pluggable
• 2x15 XFP Electrical Interface
• IEEE802.3ah PX-20D compliant
• IEEE802.3av PR-30D compliant
• Optical Transmitter
1577nm CW Mode EML
10.3125Gb/s data rate
LVCML AC Coupled input
1490nm CW Mode DFB Laser
1.25Gb/s data rate
LVPECL AC Coupled input
• Optical Receiver
1270nm Burst Mode APD/TIA receiver
LVCML DC Coupled output
1310nm Burst Mode APD/TIA receiver
1.25Gb/s data rate
• LVPECL DC Coupled output
• Control and Monitor Interface
LVTTL Tx_Disable
LVTTL Mod_Abs
LVTTL Rx_LOS
LVTTL Rx_RSSI_Tri
• I2C Serial Data
• SCL Serial Clock Input
• SDA Serial Data I/O
