LTF7219 SFP+ 10G-EPON SC/APC ONU Transceiver Symmetrical
10.3125Gb/s
The LTF7219 10G EPON ONU Transceiver module has been designed for low cost Point-to-Multi Point (P2MP) Fiber to the Home (FTTH), Building or Curb (FTTx) applications employing high-speed Burst Mode TDM Upstream at 10.3125Gb/s and CW Downstream at 10.3125Gb/s. The LTF7219 is based on IEEE 802.3av 10GBASE-PR30. It is fabricated with a die cast metal housing and cage assembly and the electrical interface refers to the industry standard SFP+.
10G EPON ONU | LTF7219-BCA+ LTF7219-BHA+ |
SFP+ | SC/APC | 20km | C,H | 4~9dBm | 10.3125Gb/s | 1270nm | -28.5dBm | 10.325Gb/s | 1577nm |
• Symmetric 10G-EPON Access networks
• Fiber to the Home
• Fiber to the Building
• Fiber to the Curb
• 2x10 SFP+ Die Cast Housing
• SC/APC Optical Receptacle
• One single-mode fiber
• Bidirectional Operation
• Dual Wavelength
• Low Power Consumption
• 10.3125Gb/s Burst Mode Tx Data Rate
• 10.3125Gb/s CW Mode Rx Data Rate
• Single 3.3V DC Input Voltage
