Package Type
data_rate
wavelength
reach
Temperature
Protocol
LTF1325 SFP28 Optical Transceiver
24.33Gb/s to 25.78Gb/s 1310nm 10km
The LTF1325  is intended for 10km reach service from 24.33Gb/s to 25.78Gb/s 1310nm single mode high-speed communications equipment where low-cost, extraordinary performance and reliability are essential. It consumes low power, operates base on 3.3V DC power supply and is offered in the commercial temperature range. They are compliant with  SFP28 MSA , SFF-8431  and SFF-8432. The low jitter and low bit error rate optical assembly features a 1310nm DML laser transmitter and PIN/TIA receiver.
LTF1325-BC+
LTF1325-BH+
SFP28 LC 10km C,H Single-mode 1310nm 24.33~25.78Gb/s -5~3dBm -10.6dBm
• 25G BASE-LR Ethernet
• CPRI 25G
• OTU4
• LC Duplex optical interface
• Maximum link length of 10km
• 24.33Gb/s to 25.78Gb/s data links
• Power consumption<1.5W
• High performance 1310 nm DML laser
• Built-in CDR
• Standards:
   SFP28 MSA
   SFF-8431
   SFF-8432
尊敬的访客
本网站可能会收集用户的个人信息,包括但不限于姓名、联系方式、电子邮件地址、地理位置等。 这些信息将用于提供更好的用户体验和个性化服务。单击“接受”以激活它们或“如果你不想要就拒绝。 请参阅我们的《隐私政策》 ,以了解如何在我们的网站上使用它们的更多信息。您可以在您方便的时候在这里更改设置。
拒绝
接受
