LTF132X SFP28 Optical Transceiver
24.33Gb/s to 25.78Gb/s MWDM 10km
The LTF132x SFP28 footprint transceiver is intended for 10km reach service from 24.33Gb/s to 25.78Gb/s 12 wavelengths MWDM single mode high-speed communications equipment where low-cost, extraordinary performance and reliability are essential. It consumes low power, operates base on 3.3V DC power supply and is offered in the extended temperature range. They are compliant with SFP28 MSA , SFF-8472 and SFF-8432. The low jitter and low bit error rate optical assembly features a MWDM DML laser transmitter. It incorporates the SFP+ MSA LVTTL Loss of Signal (Rx_LOS), Tx Fault (Tx_FAULT), MOD_ABS and Tx Disable (Tx_DIS) monitor and control functions. It utilizes inter-nal clock and data recovery (CDR) units on transmitter and the receiver chains for low jitter compliance. The differential AC coupled Tx and Rx data interfaces are CML compatible.
LTF132X-BE+ | SFP28 | LC | 10km | E/C | Single-mode | 1267.5nm 1274.5nm 1287.5nm 1294.5nm 1307.5nm 1314.5nm 1327.5nm 1334.5nm 1347.5nm 1354.5nm 1367.5nm 1374.5nm |
25.78125Gb/s | 2~7dBm | -14dBm(OMA) |
• 25G BASE-LR Ethernet
• 5G Wireless
• LC Duplex optical interface
• Maximum link length of 10km
• 24.33Gb/s to 25.78Gb/s data links
• +3.3 V power supply
• Low DC power consumption
• SFP+ MSA compliant package
• High performance DML laser
• Single Mode operation
• Built-in CDR
• Case Operating temperature ranges:
• Extended: -20 to +85ºC for AAU /RRU
• Commercial : 0 to 70ºC for DU /BBU
• Data and Control Interfaces:
• Tx Data CML/AC Coupled
• Rx Data CML/AC Coupled
• Tx_DIS LVTTL
• Tx_FAULT LVTTL
• Rx_LOS LVTTL
• MOD_ABS LVTTL
• 2-wire I2C data bus
• RoHS 6 compliance
