LMF2018W/LMF7018W SFP56 Optical Transceiver
50G 53.125Gb/s 1310nm 10km
The LMF2018W/LMF7018W is intended for 10km reach service from 10.31Gb/s to 53.125Gb/s 1270nm/1330 single mode high-speed communications equipment where low-cost, extraordinary performance and reliability are essential. It consumes low power, operates base on 3.3V DC power supply and is offered in the commercial temperature range. They are compliant with SFP56 MSA , SFF-8431 and SFF-8432. The low jitter and low bit error rate optical assembly features a 1270nm/1330nm DML laser transmitter and PIN/TIA receiver.
LMF2018W-BH+ LMF7018W-BH+ | SFP56 | LC | 10km | C | single-mode | 1270nm/1330nm | 50Gb/s | -4.5~4.2dBm | -8.9dBm(OMA) |
50G BASE-LR
5G wireless
CPRI
SFP56 Pin assignment compliant
Hot Pluggable SFP56 form factor
10km link on SMF
Uncooled DML transmitter
Case Operating Temperature:Commercial: -40 to 85ºC
Digital diagnostic capabilities
+3.3V power supply
LC-Duplex Optical Receptacle
RoHS6
