LMF3018W-BH+ SFP56 Optical Transceiver
50G 53.125Gb/s CWDM 10km
The LMF301XC is intended for CWDM 10km reach service from 10.31Gb/s to 53.125Gb/s CWDM single mode high-speed communications equipment where low-cost, extraordinary performance and reliability are essential. It consumes low power, operates base on 3.3V DC power supply and is offered in the commercial temperature range. They are compliant with SFP56 MSA , SFF-8431 and SFF-8432. The low jitter and low bit error rate optical assembly features a CWDM DML laser transmitter and PIN/TIA receiver.
LMF301XC-BH+ | SFP56 | LC | 10km | C | single-mode | 1271nm 1291nm 1311nm 1331nm 1351nm 1371nm | 50Gb/s | -4.5~4.2dBm | -8.9dBm(OMA) |
50G BASE-LR
5G wireless
SFP56 Pin assignment compliant
Hot Pluggable SFP56 form factor
10km link on SMF
Uncooled DML transmitter
Case Operating Temperature:Commercial: -40 to 85ºC
Digital diagnostic capabilities
+3.3V power supply
LC-Duplex Optical Receptacle
RoHS6
