LTF3228 SFP28 Optical Transceiver
25Gb/s 40km
The LTF3228 SFP+ footprint transceiver is intended for 40km reach service from 24.33Gb/s to 25.78Gb/s Tx1310nm/Rx1270 single
mode high-speed communications equipment where low-cost, extraordinary performance and reliability are essential. It consumes low
power, operates base on 3.3V DC power supply and is offered in the Industrial temperature range. They are compliant with SFP28 MSA , SFF-
8431 and SFF-8432. The low jitter and low bit error rate optical assembly features a 1330nm DML laser transmitter and APD/TIA receiver. It
incorporates the SFP+ MSA LVTTL Loss of Signal (Rx_LOS), Tx Fault (Tx_FAULT), MOD_ABS and Tx Disable (Tx_DIS) monitor and control
functions . It utilizes internal clock and data recovery (CDR) units on transmitter and the receiver chains for low jitter compliance. The differential
AC coupled Tx and Rx data interfaces are CML compatible.
Part Number | Package | Interface | Reach | Temp | Fiber Type | Wavelength | Rate | Tx Output | Rx Input |
LTF3228-BH+ | SFP28 | LC | 40km | H | single-mode | 25.78Gb/s | 1310nm | -18.5dBm | 25.78Gb/s |
• 25G BASE-ER Ethernet
• CPRI 25G
• OTU4
• LC Bi-direction optical interface
• Maximum link length of 40km
• Low DC power consumption
• 2x10 SFP+ MSA compliant package
• High performance 1310 nm DML laser
• High sensitivity APD/TIA optical receiver
• Single Mode operation
• BER < 5X10-5
• Built-in CDR
