LTF2302 SFP+ Bidirectional Transceiver
10Gb/s 20km
The LTF2302 SFP+ transceiver is intended for 20km reach service from 9.95Gb/s to 10.3125Gb/s 1270nm/1330nm single mode high-speed communications equipment where low-cost, extraordinary performance and reliability are essential. It consumes low power, operates over the commercial and industrial temperature ranges and employs a single 3.3V DC power supply. The low jitter and low bit error rate optical assembly features a 1270nm DFB laser transmitter and a PIN/TIA receiver. It incorporates the SFP+ MSA LVTTL Loss of Signal (Rx_LOS), Tx Fault (Tx_FAULT), MOD_ABS and Tx Disable (Tx_DIS) monitor and control functions. The differential AC coupled Tx and Rx data interfaces are CML compatible. The device is Class I laser safety compliant.
10G BIDI | LTF2302-BC+ LTF2302-BH+ |
SFP+ | LC/UPC | 20km | C,H | -4.2~4dBm | 10.3125Gb/s | 1270nm | -14.4dBm | 10.3125Gb/s | 1330nm |
• High-speed storage area networks
• Computer cluster cross-connect
• Custom high-speed data pipes
• IEEE 802.3ae Base-LR/LW
• Single 3.3V DC Supply
• 20km Reach
• 2x10 SFP+ Package Outline
• LC Optical Interface
• Dual Wavelength (WDM) Bidirectional Transmission
• 9.95 to 10.3125Gb/s Data Rate
• 1270nm CW Mode DFB Optical Transmitter
• 1330nm CW Mode PIN Optical Receiver
