LTE4305 SFP Bidirectional Transceiver
1250Mb/s 10km
The LTE4305 SFP transceiver is intended for 10km reach service in 1250Mb/s, employing high-speed CW mode receivers/transmitters in 1250Mb/s symmetrical duplex data links. It refers to the requirements of IEEE 802.3ah 1000BASE-BX10, consumes low power and operates from a single 3.3V DC power supply. The industry standard 2x10 small form pluggable (SFP) package is fabricated with a rugged die cast metal housing and cage assembly. The low jitter and low bit error rate optical assemblies features a DFB laser transmitter and PIN/TIA receiver. It incorporates the SFP MSA Loss of Signal (Rx_LOS), Tx Fault (Tx_FAULT),Tx Disable(Tx_DISABLE) monitor and controls functions. The devices are Class I laser safety compliant.
1.25G BIDI | LTE4305-BC+ | SFP | LC/UPC | 10km | C | -9~-3dBm | 1.25Gb/s | 1490nm | -19.5dBm | 1.25Gb/s | 1310nm |
• Access Networks
• Fiber to the Home, Curb, Office (FTTx)
• Point to Point FTTx Service (P2P)
• Up to 10km Reach
• Bidirectional Transceiver
• Dual Wavelength
• Single Fiber
• Full Duplex Operation
• IEEE 802.3ah 1000BASE-BX10
• Single 3.3V DC supply
• Low Power Consumption
• 2x10 SFP package outlines
• Bail Latching Mechanism
• LC Optical Receptacle
