LTE4324-BC+ SFP Bidirectional Transceiver
1250Mb/s 40km
The LTE4324-BC+ SFP transceiver is intended for 40km reach service in 1250Mb/s, employing high-speed CW mode receivers/transmitters in 1250Mb/s symmetrical duplex data links. It refers to the requirements of IEEE 802.3ah, consumes low power and operates from a single 3.3V DC power supply. The industry standard 2x10 small form pluggable (SFP) package is fabricated with a rugged die cast metal housing and cage assembly. The low jitter and low bit error rate optical assemblies features a DFB laser transmitter and PIN/TIA receiver. It incorporates the SFP MSA Loss of Signal (Rx_LOS), Tx Fault (Tx_FAULT) monitor and controls functions and digital diagnostic monitor feature which can be accessed via the 2-wire interface.
1.25G BIDI | LTE4324-BC+ | SFP | LC/UPC | 40km | C | -2~3dBm | 1.25Gb/s | 1490nm | -23dBm | 1.25Gb/s | 1310nm |
• Gigabit Ethernet Access Networks
• Point to Point FTTx Service
• 1490nm CW mode Tx
• 1310nm CW mode Rx
• IEEE 802.3ah
• Single 3.3V DC supply
• Reach: 40km
• 2x10 SFP package outlines
• Bail Latching Mechanism
• LC Optical Receptacle
• Single fiber, full duplex operation
• Dual wavelength (WDM) bidirectional transmission
• High sensitivity PIN/TIA receiver subassembly
• High performance 1490nm DFB laser
